Re: Tractor Repair
Posted by ken house on April 02, 2013 at 07:23:07 from (173.242.241.169):
In Reply to: Tractor Repair posted by Frank Castro on April 01, 2013 at 16:38:53:
take a spark plug and fasten a wire to the base, fasten the other end to a convenient ground, on the tractor, near the coil. remove coil wire from distributor and place on spark plug that you have just constructed. remove coil wire from the side of distributor, turn on switch, ground loose end of wire to coil, strike the loose end to ground, repeatedly, you should get a spark on the spark plug. if not, coil is bad.
