IH 340 utility oil pan helicoil
Posted by Mark W. on April 03, 2013 at 07:04:38 from (64.83.132.2):
So I finally found a good used oil pan for my 340 utility. I know that one of the threads in the block is stripped. Someone recommended a helicoil. Does anyone know of hand what size I would need to get? I am not near my tractor and would like to pick one up if you gentlemen think it is what would work.
