Mark - I'm 99% certain those pan bolts are 5/16-18. But have someone else confirm before you go buying a helicoil, tap and inserter tool!
Another (probably cheaper) option: Drill and retap the stripped hole the next screw size larger (3/8-16). Then use a 3/8-16 bolt (or a 3/8-16 socket head cap screw if a 3/8 bolt head is too big) in that hole. Of course you would need to drill out the mating hole in the pan flange to fit the larger pan bolt.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
