Re: Question on Coil wire hook up on 12 v conversion
Posted by old on April 03, 2013 at 09:14:49 from (209.86.226.40):
In Reply to: Question on Coil wire hook up on 12 v conversion posted by cbrown on April 03, 2013 at 09:06:32:
Is it a generator or an alternator 12 volt system??? If an alternator you have about a 99% chance it is - ground and if you hook it up + you will let the smoke out the moment you hook up the battery. As for the coil you always hook the same side of the coil as your ground so if you do a - ground the - goes to the distributor
