Re: By pass ameter?
Posted by nebraska cowman on April 06, 2013 at 08:46:54 from (166.182.3.7):
In Reply to: By pass ameter? posted by irwing52 on April 06, 2013 at 08:20:44:
You are painting your question with a pretty broad brush. Yes, you can run the tractor. That's the simple answer. depending on whether you have a generator or alternator and how it is hooked up would be the question. The current hast to have some path to go to or it can do bad things. State your question a little more clearly and someone will straighten you out. A stock M would have a separate switch for the ignition independent of the light switch.
