By pass ameter?
Posted by irwing52 on April 06, 2013 at 08:20:44 from (69.55.38.93):
Hey friends; I need to know if I can by pass the ameter and relay switch on a farmall m, I have ordered parts but it takes about a week to get here and can I run the tractor without this switch. The switch as you probably know is in the ameter box runs the light switch ignition switch.
