oil canister on Farmall 400
Posted by N.D. Farmall H Puller on April 07, 2013 at 18:57:27 from (69.178.202.56):
Overhauled my 400 everything went fine started it up today fired right up after getting the timing right. Had it running for 15 to 20 seconds then it started to push oil out of the top of the oil canister. We had to buy a new bolt because the old one was bent. Could it be that the hole on the side of the bolt is too small as it is maybe the size of a safety pin.The one on the bottom is close to 1/8th inch. Threw the old one away so can't compare. Is there a conversion kit to convert it over to a spin on filter. Need some idea's.
