The new bolt will have flat surface around the under side of the hex that should match the flat surface at the hole on top of the can. If these 2 are used parts what usually transpires is 1 or both mating surfaces gets rounded from over tightening, a lot times the sealing rubber at bottom leaks & not replaced often gets hard, same at top with the soft brass ring. The guy changes oil, whoops slight leak, tightens this time & gets by, now over 60 years time you can see what could be the problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
