Posted by 47 Bill on April 08, 2013 at 03:03:25 from (173.166.167.77):
I have liftall out, both couplings removed from lift all and countershaft.Piece of keystock welded on socket worked great. Can transmission driving shaft oil seal be removed without splitting tractor? Is there enough room to remove bolt and coupling after removing connector between clutch shaft and transmission driving shaft? Any tips appreciated.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
