Re: Super M Mainshaft oil seal
Posted by Janicholson on April 08, 2013 at 06:16:35 from (199.17.6.78):
In Reply to: Super M Mainshaft oil seal posted by 47 Bill on April 08, 2013 at 03:03:25:
If the clutch pressure plate has three holes on the area near the fingers, use three of the PP bolts in those holes to compress the Tension on the plate. This allows the clutch shaft to be removed more easily. (not easy, just more easily)
The connection bolts mentioned are a bit of a pain, but the spider (cross) connector must be carefully put back the way it is. It can be reversed and it will look correct but not allow the pilot snout to engage the crank pilot bearing. Once the shaft is out it is easy to do the seal. (don't pull the input shaft out, bearings may fall into the case and require much physical training to replace.) Jim
