The answers in order: The driven gears in the transmission are sliding into mesh with the drive gears. Pulling the lever into a gear position with the clutch pedal up, causes those teeth to smash into each other (not good) they resist this smashing with noise and little pieces of them are splintered off into the oil. Do not do this. Fifth gear is a direct coupling of the input shaft to the output shaft. (no gears involved in the coupling, just splines on the 4th fifth slider. It is worn out from the above smashing into gear. It ill not work until the slider and input shaft and intermediate pilot bearing are replaced. The PTO may be gummed up on the inside or the shifter for it is not working. If you can turn it with a pipe wrench while the engine is off and the tractor is in gear, it is probably gust gummed up. Using it with a mower (with a overrunning clutch) will get it to be operational. If broken it will need to be removed (also easy. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
