If it was an ice problem, it will work now that it has warmed up.
Changing the oil will not hurt anything but if it doesn't work now it won't work after changing it.
What did the weird noise sound like?
Check your engine oil level and your hydraulic oil level. If the hydraulics are low and the engine is over full, the pump seal has failed and pumped all your hydraulic oil into the engine.
Another possibility is the pump has seized and sheared the key off the drive gear, or the nut has come off the pump drive gear and the gear has fallen into the oil pan.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
