Re: Model C float setting
Posted by pete 23 on April 10, 2013 at 17:10:56 from (74.47.40.242):
In Reply to: Model C float setting posted by Kevin in Minnesota on April 10, 2013 at 16:49:06:
If your float sets parallel with the carb body, the setting is not the problem. It is either too stiff on the hinge, leaky float , rubbing on side , needle is leaking or gasket under seat is not sealing. I like to test the needle and seat with vacuum, usually just sucking on it with mouth. Probably needs staking to make a good seat.
