I would change 1@2 with 3@4 plugs then wires you have fire or it wouldnt run so you either have two bad plugs or wires then compression check then tappet clearence. But your dist is OK or 3@4 wouldnt fire. Are you sure the wires are in the correct order as your firing is 1342. Those engines will run on tw cycle if the right cycls are firing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
