Re: Famall H Stuck between gears?
Posted by Bob M on April 14, 2013 at 11:00:29 from (67.240.171.136):
In Reply to: Re: Famall H Stuck between gears? posted by Janicholson on April 14, 2013 at 10:22:43:
Tip: If the tractor is not sitting on level, hard ground you may find the shifter rails cannot be moved by prying with a large screwdriver. This is on account of torque load on the transmission gearing. If so, do this:
Jack up either rear wheel just clear of the ground. Then rock the wheel forward and backward a bit (it need only move a small fraction of an inch at the rim). The shifter rails should now move easily.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
