Re: Farmall 560 pto
Posted by pete 23 on April 14, 2013 at 11:04:54 from (74.47.40.242):
In Reply to: Farmall 560 pto posted by Busted on April 14, 2013 at 07:31:28:
Some drag is normal when cold. Should be able to adjust the rod to get good tension on brake and stop it. The over center clutch is latest style, early ones used planetery same as a 450 etc. You probably have worn keyways in operating shaft, worn overcenter mechanism inside or warped discs. You could also try changing the oil in unit to hy-tran as the old oil gets really thick and full of gunk. Only hold a short quart.
