Re: Re: Re: Re: fast speed gears H
Posted by brian on November 16, 2000 at 06:23:46 from (205.188.195.156):
In Reply to: Re: Re: Re: fast speed gears H posted by Denny on November 15, 2000 at 13:45:06:
I wondered if this was the M&W 9-speed -- but you can shift all five forwards plus reverse into it.
The road gear plus overdrive goes about 25mph. I was told that the M&W unit had a cable coming out of the front of the transmission, inside of the clutch housing, to activate it. Mine has a shaft coming out of the right side of the transmission, with an attached lever, and a rod coming up to the Lift-all bracket. When shifting into fifth (road) gear the shift lever does not seem to travel as far -- was there some kind of lockout on the M&W to keep you from shifting into fifth plus overdrive for safety reasons?
Post A Followup
: Re: Re: Re: Re: Re: fast speed gears H
