Re: Alt. conversion on H
Posted by mkirsch on April 22, 2013 at 07:11:34 from (64.80.110.74):
In Reply to: Alt. conversion on H posted by DTK on April 22, 2013 at 05:45:26:
The excite wire needs to be on a switch, otherwise it will run the battery down when the tractor isn't running.
I just run a wire from the + side of the coil up to a big diode, then on to the excite terminal in the alternator. Then the ignition switch also excites the alternator.
Sounds like you might have a magneto.
If you take power off the starter side of the starter switch, you will have to hold down the starter button, while the engine is running, until the alternator excites. Not good for the starter, in my mind.
I don't think there's any way around this, but to run a separate wire and switch to excite the alternator.
