Re: Alt. conversion on H
Posted by DTK on April 22, 2013 at 07:37:36 from (64.72.182.117):
In Reply to: Re: Alt. conversion on H posted by mkirsch on April 22, 2013 at 07:11:34:
You are pretty sharp, I should have said its a magneto ign.
Should I leave the field resistor term. Unused ? Would the
momentary contact from the starter switch be enough to excite
the alt.? Thanks DTK
