Posted by Farmalittle on April 22, 2013 at 07:27:06 from (63.142.125.219):
I have a 1940 H that is still 6 volt, and I would like to keep it that way. I am building new battery cables out of 2/0 welding lead with crimped lugs. I am going to follow that up by using heat shrink tubing on the ends.
Does it make sense to use stainless steel nuts, bolts, and washers at the electrical connections such as the starter bolt where the ground connection is made, the starter lug, and at the starter switch? I am thinking that since stainless is less resistant to corrosion that it would be one more line of defense. Of course, whichever way I go, I will coat the connections with dielectric grease.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
