Re: IH 574 1975 Three point linkage stuck
Posted by jimb2 on April 23, 2013 at 16:36:44 from (99.241.76.141):
In Reply to: IH 574 1975 Three point linkage stuck posted by DavidP, South Wales on April 23, 2013 at 07:27:19:
Hi David,
Make sure draft control lever is fully forward.
From archives:
3 pt will not go down:
There is cover on the right side, in front of the rock-shaft. Remove and check if the spool valve moves with the position lever. Make sure the draft lever is down. It has a long spring, with a rod, maybe the spring is unhooked.
Maybe the unload valve is stuck. Check with engine running, raise the hitch and at the same pull the remote hydraulic lever. If the hitch raises, you have dirt in the unload valve. This valve is under the seat and you have to remove the large plug for access. One trick is loosen the large plug, unload valve, 2 turns and start the engine, the hitch should raise if the valve is stuck. It has a small hole in the valve and just blow the dirt with air. Install new O rings.
Bernard le mécano Québec Canada
Hope this helps
JimB
