Simple test ground the field if that makes it charge the reg is bad if it doesent charge the gen is bad this will work if ALL componets have a ground. If you have a volt meter check the voltage at the batt term on the reg should read batt volts. When the motor is running it should read 7.2 or so. Using OHM meter ALL componets tshould have ground to the battery. Does the ammeter show discharge with the lite on meter can also be bad.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
