Re: Farmall 350 T/A clutch problem
Posted by D Slater on April 24, 2013 at 18:24:28 from (184.15.15.19):
In Reply to: Re: Farmall 350 T/A clutch problem posted by riverbend on April 24, 2013 at 16:33:58:
If I remember correct from the friction disc hub to the fingers is about 1-5/8. That's just a ball park number though. Think you need to split behind the engine and start over with the t/a clutch. If using the same main clutch, set the correct free play for it before removing the engine. When all the t/a clutch parts and linkage is in to spec. Turn the transmission shaft by hand to make sure the t/a clutch releases when the clutch pedal is pushed down. also when the t/a lever is pulled back before the engine is installed.
360655 is a 300 shaft. The 350 shaft will move the release bearing more if the clutch shaft movement was equal for both. 350 clutch pedal has the clutch rod hole closer to the pivot point than a 300. But a 300 has a stop bolt to limit clutch pedal travel so they end up close. But if parts from the two are mixed you can have a problem.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
