Re: Farmall 350 T/A clutch problem
Posted by riverbend on April 24, 2013 at 16:33:58 from (184.12.41.164):
In Reply to: Re: Farmall 350 T/A clutch problem posted by D Slater on April 23, 2013 at 17:31:31:
Do you have any specs for the pressure plate ?
For example:
How far the friction surface should extend below the mounting surface of the cover.
The distance from the friction surface to the tips of the levers.
I found part of the problem. One of the levers parted company with the pressure plate. That's not all of it though, previously I had to put in an 1/8" spacer between the pressure plate and the carrier to make it work at all.
Greg
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
