International Model 784 Brake Bleeding Procedure
Posted by John Litzelman on April 25, 2013 at 14:50:41 from (98.250.205.187):
I have an old note (dtd 2018 by Jim B2) for a procedure to bleed the brakes on a model 674 which states: ".....run the tractor until the HY tran fluid reaches operating temperature. Run the engine at fast idle (14-1600 RPM), block rear wheels: (1). with tubing connected to nipple on bleed screw and other end in clean bucket, loosen bleed screw and let hydraulic fluid drain until air bubble free, then close screw; Repeat on other brake. DO NOT pump brakes when bleeding."
I assume this procedure will also apply to my model 784 - please advise (Jim B2 or others familiar with this model) of any changes if so.
