Re: International Model 784 Brake Bleeding Procedure
Posted by Jim Naden on April 25, 2013 at 17:40:19 from (12.74.49.126):
In Reply to: International Model 784 Brake Bleeding Procedure posted by John Litzelman on April 25, 2013 at 14:50:41:
Couple steps missing that apply to all tractors in this series.
Pinch off the return tube from the master cylinder reservoir to the transmission.
Run the tubing into the transmission fill hole. No need to waste fluid.
Do, slowly pump the brake, until the fluid runs free of bubbles.
After the left and right brake have been bled individually open both bleeders and pump both brakes simultaneously until fluid runs with no bubbles.
