#3 cylinder not working
Posted by Scott R Kincaid on November 17, 2000 at 10:24:38 from (63.36.53.137):
I just spoke with my local case mechanic who had just finished rebuilding the carberator on my 1950 H. The #3 cylinder will not fire. there is good spark and a compression check showed 85lbs across all four cylinders with no leak off. He stated that it appears the valves are not stuck, but he did not open it up. Trying to eliminate any easy fixes before resorting to opening it up. Any suggestions would be geatly appreciated.
Post A Followup
: Re: #3 cylinder not working
