Re: #3 cylinder not working
Posted by Pappy on November 17, 2000 at 19:51:13 from (205.188.198.28):
In Reply to: #3 cylinder not working posted by Scott R Kincaid on November 17, 2000 at 10:24:38:
We had an H with exactly the same problem. Found out it was a bad manifold gasket, just like John in Iowa says. Start the tractor, spray some carb cleaner under the intake manifold at the gasket. You might hear it start to run perfectly. That's what happened to us. A new gasket solved the problem.
Post A Followup
: Re: Re: #3 cylinder not working
