Posted by kopeck on May 01, 2013 at 17:40:26 from (69.50.52.188):
In Reply to: Farmall A, Round 3 posted by kopeck on May 01, 2013 at 08:49:14:
Thanks for the ideas guys but if you look at the thread I linked to you will see I tired almost everything you've listed.
Now the coil on the mag, might be the case, still probably easiest to test by just swapping the distributor over.
I've tried 3 carbs, 2 of which were rebuilt, one professionally.
I've tried different wires and different plugs.
Gene, do you mean off a tooth in the mag or the engine's timing is off? I do get good blue spark. This thing used to start pretty easily hand cranking, now it's nearly impossible.
I've run it with out air cleaner, propane checked the manifold. I'm thinking it's either ignition or some sort of internal manifold issue.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
