300 Utility missing out - stumped!!!
Posted by bmagee on May 04, 2013 at 18:19:29 from (50.90.101.61):
Need some advice - while plowing with my 2-bottom after an hour, it started missing out. First thing I thought was condenser. I changed points and condenser. It started again about a half an hour after plowing again. I then changed coil, new plugs, checked all wires (swapped out). I even changed gas filter.
Then when started ran great until you opened up the throttle then missed out. I bumped the timing a little and it then ran great.
I went back out and it ran great under load or when plowing, but when I lifted plow out of ground and no load, it would miss out. Did I advance timing too much or what???
Thanks for the help
