Re: 300 Utility missing out - stumped!!!
Posted by Janicholson on May 04, 2013 at 20:33:49 from (74.60.94.18):
In Reply to: 300 Utility missing out - stumped!!! posted by bmagee on May 04, 2013 at 18:19:29:
If timing it fixed it to some degree, check the springs and mechanism in the centrifugal advance (under the breaker point plate in the distributor) If they are rusty or broken, the timing will be off (either at idle, or at full power. but incorrect at the other speed.) Fuel could be an issue. Over correcting the mixture could do it, but your timing change is leading me to think about the advance. Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
