Re: Hey RustyFarmall!
Posted by IAtractorKid on May 05, 2013 at 10:36:29 from (184.97.54.243):
In Reply to: Re: Hey RustyFarmall! posted by rustyfarmall on May 05, 2013 at 07:01:23:
I see, well hopefully you are enjoying retirement!
Any help or thoughts you have would be
appreciated, I"ve never had this much trouble and
am at a loss at this point.
Yes the idle metering jet was broken off. I
drilled out what was left of it, chased the
threads and installed a new one.
Yes fuel inlet screen was removed and
cleaned...entire carb was disassembled and cleaned
when I rebuilt.
As best I can tell, the float has free travel and
is not binding or rubbing on anything. I did have
trouble with the needle sticking (rubber tipped as
that is all I can fins). 3rd one I tried finally
seemed to work.
The venturi was a little beat up, looks like its
been dropped a few times before. Anyway tractor
runs a little rough at idle, slightly better with
idle adjusting screw all the way in. Tractor lacks
power in 4th/5th gear, and also just randomly dies
after its warmed up. Starts right back up after it
dies with no choke. I have verified good fuel flow
from the tank and adjusted the governor. Also
checked for manifold/gasket leaks while tractor
was running with propane torch.
My dad still thinks its a carb problem, at this
point I am thinking ignition. Not sure what to
start checking though...everything is new - plugs,
wires, points, condenser, coil, alternator,
battery and cables and wiring.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
