Re: SH rough idle, randomly dies, lacks power
Posted by Janicholson on May 05, 2013 at 11:50:56 from (199.17.6.78):
In Reply to: SH rough idle, randomly dies, lacks power posted by IAtractorKid on May 05, 2013 at 10:51:03:
A worn distributor shaft will do those things. put a timing light on the coil wire not #1 then shin it at the pulley and look for wild variation in Flash location. if found, the dist. cam bushing may be toast. The loose bearing allows wild timing. and the total effect may be stalling if the points are set even a little close. (best first guess) Coil replacement might be the second. Does it get hot! Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
