Re: Farmall M Starter Problem
Posted by Melvin Ware on May 06, 2013 at 13:09:46 from (75.200.11.210):
In Reply to: Re: Farmall M Starter Problem posted by Janicholson on May 04, 2013 at 20:29:15:
How does the Bendix drive attach to the armature? I removed the two bolts attaching the starter to the drive housing but when I go to pry the drive housing away from the starter, the armature is coming out also.
Local shop says he"ll replace the drive for $40 which seems reasonable. May just let him deal with it. Also said he"ll check to make sure it has the correct brushes since this is probably a 6 volt starter and the tractor has ben converted to 12 volts. Says the original 6 volt brushes used on 12 volt system will shorten the gear life. Had you heard this before? He"ll also check the bushings.
