Re: Farmall M Starter Problem
Posted by Janicholson on May 06, 2013 at 17:36:20 from (74.60.94.18):
In Reply to: Re: Farmall M Starter Problem posted by Melvin Ware on May 06, 2013 at 13:09:46:
I just take things apart and repair. I have so many years doing it that it is second nature. The drive end should come off of the field frame with an easy tap with a wooden block or plastic hammer. There is to my knowledge no such thing as a 12volt brush. putting new brushes in it is a good idea. For 40 let the man do it. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
