Re: farmall super a hard steering
Posted by RTR on May 09, 2013 at 11:43:13 from (216.226.179.180):
In Reply to: farmall super a hard steering posted by CharlieNJ on May 08, 2013 at 10:16:21:
I have several of the kits that are available and the kit does specify that you need to ream out or cut the bushing down to fit your parts. I found that out the hard way by having it all apart and it "not fitting" when I was hoping to get it back together same day. Just get a kit online and have a machinist match the new parts to your shaft, casting, etc. Should work well.
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
