1940 H distributor
Posted by Mike D. on May 13, 2013 at 17:33:32 from (50.36.78.104):
I have a 1940 H with a vertical distributor and the gears on the end of the distributor are worn out and all so the gears on the drive shaft are worn out and the gears are at a angle and all the parts I see on the internet are straight and look a bit different. Do they make the angled drive shaft gear"s for both pieces , or is there an alternative option to fix the distributor.
