Re: 1940 H distributor
Posted by Tom Fleming on May 13, 2013 at 17:39:56 from (67.20.233.75):
In Reply to: 1940 H distributor posted by Mike D. on May 13, 2013 at 17:33:32:
The verticle distributor drive was an aftermarket option. If you want to be truly correct, you need a straight shaft one. The 90 degree ones were used when an inline hydraulic pump was added. There may be other reasons I am not aware of, but that is one that comes to mind.
get a decent one, straight shaft, and put her back together.
This post was edited by Tom Fleming at 18:14:25 05/13/13.
