Fuel flow in your photo is more than adequate - no problem there!
From your description (stumbling, rough idle, choke req'd in 4th - 5th) the problem is a chronic lean condition. If you cannot correct it by opening the carb load screw the carburetor needs disassembly and a THOROUGH cleaning.
As for timing you don't need a timing light. Simply set the pulley notch at the pointer with the distributor button pointing to the #1 nipple on the cap. Now stick a mirror so you can observe the ammeter while standing alongside the distributor. Turn on the ignition and watch the ammeter as you slowly rotate the distributor back and forth. Timing is correct the instant the ammeter returns to center while the distributor housing is being rotated COUNTERclockwise.
Don't forget to turn off the ignition as soon as you are done!
