Re: Farmall SH Fuel Flow and Timing
Posted by IAtractorKid on May 19, 2013 at 10:25:29 from (216.161.121.217):
In Reply to: Re: Farmall SH Fuel Flow and Timing posted by Bob M on May 19, 2013 at 08:42:28:
I have had the carb apart multiple times to clean already and am not having any luck. I have never had any trouble with other carbs I have gone through. I have even tried bead blasting and baking this one in a heat treat oven to burn anything out. New idle adjusting screw but the load screw is the one that came out of it and has a very small groove worn, wonder if that's causing any problems. I also wonder if someone has previously closed them too hard and damaged the seats? If it has any relavence, this is the carb that had the broken jet inside and bent choke plate when I got it. Venturi looms like it has been dropped a few times. I smoothed the rough spots off a little but that's it.
