If so, it may need a field flash to initially get it charging. With the engine running at 1/2 throttle, use a jumper wire to connect the BAT stud on the alternator rear, to the regulator blade marked #1 on the rear edge of the alternator case. Normally you only need to do this with a new installation or a machine that has not been started for a long time.
Make sure the fan belt is not loose and slipping. Many a Farmall no charge situation has been caused by a slipping fan belt.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
