farmall 350 1 wire alternator
Posted by ihjason on May 19, 2013 at 16:35:58 from (74.127.133.90):
I put a one wire alternator on my 350. I ran the wire from the alternator to the amp gauge and then to the battery side of the solenoid. It still doesn"t show any charge. It also doesn"t show discharge when I push the start button. The gauge does work. I run the tractor up wide open to try to get it to start charging. I have tried running a ground from the alternator housing to the battery to make sure it is grounded.
