Re: farmall 350 1 wire alternator
Posted by mkirsch on May 20, 2013 at 05:20:55 from (64.80.110.74):
In Reply to: farmall 350 1 wire alternator posted by ihjason on May 19, 2013 at 16:35:58:
Did you connect all the wires to the same post on the ammeter?
The electricity has to go THROUGH the ammeter in order for it to register any charge/discharge.
The alternator, ignition switch, and light switch should all be connected to one post.
The battery should be connected to the other post, all by itself.
If the ammeter then reads backwards, switch posts.
