Re: Another charging system post
Posted by Jim Becker on May 23, 2013 at 14:48:10 from (173.57.153.141):
In Reply to: Another charging system post posted by Bob M on May 23, 2013 at 14:18:40:
If the switch is wired in and the resistor is bad, I believe this test will measure the resistance back through the generator field coil (giving a false appearance of GOOD). If you disconnect the wire from the generator F to the switch and set the switch on L, you will get a good reading from the resistor. It should be 2.8 ohms.
By the way, you should back the third brush off a little to keep the charge under about 13 amps. As I racall, IH said to go no closer than 3.2 bars from the other brush.
