Re: Another charging system post
Posted by Bob M on May 23, 2013 at 14:18:40 from (67.240.170.161):
In Reply to: Another charging system post posted by Dennis K (WA) on May 23, 2013 at 13:51:06:
Sounds like the field resistor (the resistor at the bottom of the light switch) has failed.
With the light switch in the "L" position take a resistance reading across the resistor. If the meter shows infinity, the resistor is bad. (I don't recall the precise resistance value but a good resistor should read several ohms).
You might also check the cutout ground. Your reading of .4 to .6 is high (it should be essentially 0 ohms).
