Re: Another charging system post
Posted by Janicholson on May 23, 2013 at 14:52:06 from (74.60.94.18):
In Reply to: Re: Another charging system post posted by Bob M on May 23, 2013 at 14:18:40:
I think a 2.5 to 3 ohm wire wound with 80 watt dissapation would do as a replacement. A ballast resistor might work well. The owner could see if it will work by hooking an ignition ballast resistor to the f terminal and to ground Jim
