Re: IH 2504 What are all these levers?
Posted by karl f on May 24, 2013 at 05:10:45 from (172.162.231.178):
In Reply to: Re: IH 2504 What are all these levers? posted by DeltaRed on May 23, 2013 at 17:45:00:
the torque amplifier lever could also be a reverser lever instead (you can have one or the other, not both). Can someone tell the difference from the picture we were given?
if the transmission lever doesn't have reverse that lever has to be the reverser lever. The reverser lever gives you reverse in all transmission gears. It would be more common on an industrial marketed tractor like the 2x04 series.
karl f
