Re: IH 2504 What are all these levers?
Posted by ja1724 on May 24, 2013 at 11:22:11 from (96.57.208.235):
In Reply to: IH 2504 What are all these levers? posted by karl f on May 24, 2013 at 05:10:45:
Yes, the tranny shifter does have reverse, so it must be the TA. I'll have to try it out the next time I fire her up. I guess I can verify what it is by putting the tractor in say 2nd gear, then engage that lever, then release the clutch. If I go forwards it can't be a reverser correct?
