Re: carb sticking
Posted by mkirsch on May 24, 2013 at 05:19:46 from (64.80.110.74):
In Reply to: carb sticking posted by Scott Blanchard on May 23, 2013 at 15:07:46:
There's no magic going on there. What you see is what you get.
All there is, is the seat, needle, and float.
When you hold the carb upright with the bowl removed, the float should drop and the needle should follow the float, allowing gas in.
I have not found a sure fire way to cure a sticking needle. All I've ever been able to do is keep fiddling with it until it worked.
