Re: Another charging system post
Posted by Dennis K (WA) on May 24, 2013 at 16:00:27 from (24.21.78.195):
In Reply to: Another charging system post posted by Dennis K (WA) on May 23, 2013 at 13:51:06:
Well guys I am reporting back with todays findings.
I first went with John T's suggestion checking ohms through the F wire to the switch with it disconnected. In Hi charge, as suspected '0', in Lo the meter was all over the place so then disassemble the dash and check the resistor as Bob suggested. I had a resistor connection issue and while trying to repair it I damaged the resistor. I had another switch that checked good and installed it. Readings are now 0-hi, 2.5-lo. Bob, I also rechecked readings of the gen/cutout and they are at '0'.
Jim B, I took your advise and backed off the third brush, now reading 12amps @ hi idle.
Still no obvious charge in Lo so I checked amps with my meter between the gen A and cutout gen and had 1.8-2.0 amps at hi idle. Seems low to me, thought 4-5 would be the norm.
Maybe I am chasing a ghost.
On another note,
I would like to thank you guys, Bob, Jim and Jim, and John for all your expertise and input into this forum. I and I'm sure others have learned much from you.
Keep up the good work
Dennis
sorry for the long post
